cel code P0103 - Ca peut etre causé par quoi ?
kamuro
Chuck Norris
Message par kamuro »
P0103 Mass or Volume Air Flow Circuit High Input
ca peut etre quoi ?
WRX 04 - 100% stock
DDM SPEC - Off Road Edition
UGCspawn
Message par UGCspawn »
P0103 Mass air flow sensor circuit high input. ca aurait de l'allure avec ton overrev que tu as fais. trop d'air est entré, c'est la seule idée que j,ai
Fonction over fashion!
http://two-milsim.ca/
Robert_RS2000
Message par Robert_RS2000 »
jai trouver sa une place peut-etre que sa peu aider
P0103 OBD-II Trouble Code
Technical Description
Mass Air Flow (MAF) Circuit High Input
What does that mean?
Basically this means that there is a problem with the Mass Air Flow High (MAF) sensor or circuit. A more technical description would be that the MAF circuit had higher than expected voltage (air flow).
Symptoms
You will likely not notice any serious drivability problems, although there may be symptoms such as a general decrease in power or sluggishness.
Causes
A code P0103 may mean that one or more of the following has happened:
* The MAF may be disconnected, or a wiring connection may be bad
* The MAF sensor may be damaged
* The vehicle computer may be faulty (very rare)
Possible Solutions
The simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:
* Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires.
* Inspect for any air leaks near the MAF sensor.
* Take the MAF out and clean it using a spray cleaner such as brake cleaner or electrical contact cleaner. Be gentle with the sensor.
* Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information)
* Replace the MAF sensor.
Impreza 5dr 2014
Wrx wagon 2002 Vendu
Impreza RS 2000 RIP
UGCspawn
avoir su, on l,aurait effacé :?
PsychoPat
Message par PsychoPat »
Robert_RS2000 a écrit :jai trouver sa une place peut-etre que sa peu aider
Symptoms
Causes
Possible Solutions
Peu tu me dire ou tu prend cet info ? Par PM si tu préfère.
01 RS BRP Stolen
02 WRX WRB Sold
04 WRX STI WRB Sold
08 WRX STI Aspen White gone
Robert_RS2000
jai trouver sa a moment donner
http://www.obd-codes.com/trouble_codes/
y parle pas de tout les code mais y en a une coupe qui donne des idée
Impreza 5dr 2014
Impreza RS 2000 RIP
kamuro
Chuck Norris
ben en tout cas le cel est éteint du cluster !
