Je me demandais so qqun a deja essaye ou voudrait etre le guiny pig et nous faire un petit review sur ce produit hehehe
Cross-drilled and slotted rotors give the maximum braking for performance cars under all necessary braking conditions. Precision machined holes or slots on the rotors will allow hot gases from brake pad to escape quickly to prevent skidding or locking up. It also provided quick responds to improved faster stopping power and enhancing the look of your car. Each rotor is also zinc plated to prevent rusting and is made of the best quality metals. Cross drilled and slotted patterns are precisely CNC machined for perfect fit to OEM specs for use with OEM calipers and wheels so no other upgrades is needed.
Advantages of Cross-drilled and Slotted Rotors:
-Maximum air circulation for increased cooling
-Improved wet weather braking
-Mill balanced to prevent vibration
-Zinc Plated for protection against rusting
-Increased brake pad bite
-Cooler brakes Pad
-Promote longer rotor and pad life
Voici le link de EBAY
http://cgi.ebay.com/ebaymotors/Subaru-W ... 9369QQrdZ1
