non jai pas le site web pour les Eibach
j'avais les spec mais je sais pu ou le email est rendu
les seuls chose que jai c sa
Rates: 217 front and 190 rear
lowers the car 1" to 1.25"
pis des questions avec des réponses
Q. What is the "Progressive Rate"?
A. Front 30.0 N/m, Rear 33.0 N/m
Q. What is the "Roll"?
A. It will be less than the stock suspension system.
Q. What are the I/D's and O/D's?
A. (Front) Inner diameter = 5.610", Outer diameter = 6.710" & (Rear) Inner diameter = 5.433", Outer diameter = 6.440"
Q. What is the "Free-Length"?
A. Rear (330mm), Front (270mm)
Q. Will there be a height difference?
A. Lower by 1.0" (Front), Lower by 1.2" (Rear)
