FS: Bilstein B16 (PSS10) coilover STI 08-14, 1300$
L'Frisé
Message par L'Frisé »
J'avais acheter ca pour installation sur un wrx08 convertit en 5x114.3 mais je vais le mettre a vendre prochainement et j'ai laisser la suspension STI OEM. Voici la description:
Condition: tout fonctionne tres bien mais l'ancien priprio m'avais dis de verifier les pillow ball des top plate. Les top plate avant sont ajustble GTworx. Les pillowball facilement remplaceable.
Mileage approx.: 11000km
Prix: 1800$ la moitier du prix d'une neuve... Nego en personne bien sur
On drop a 1500$
Drop a 1300$!!!
DESCRIPTION WEB BILSTEIN:
BILSTEIN 48-155830 B16 (PSS10) Suspension Kit Subaru WRX STi 08-14
MRSP: 2,802.42 $US
Position: Front and Rear
Descriptor: Front Lowered Height: 20-40mm, up to 1050kg Axle Load
Descriptor: Rear Lowered Height: 20-40mm, up to 1040kg Axle Load
The Bilstein B16 (PSS10) suspension kit is the ultimate race inspired suspension system, delivering unsurpassed driving performance in any situation. This suspension kit puts you in complete control, providing the kind of precise suspension tuning formerly available only on race cars. From a weekend of competition to daily driving, this system provides perfect handling performance for every situation. The manually adjustable damping mono-tube gas shock absorbers feature 10-stage precise compression and rebound settings, from comfort to competition. The Bilstein B16 (PSS10) suspension kit utilizes debris resistant round threads on these dampers to ensure spring adjustment remains effortless throughout the life of the kit. The surface is coated with Triple-C-Technology coating to ensure long lasting resistance to corrosion and flashy good looks.
Features and Benefits:
•Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial - 9 on B16 (PSS9), 10 on B16 (PSS10)
•Threaded body adjustable range of 20 mm at both axles
•Lowering of approx. 30-50 mm at front and rear
•Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions
•Spring plates and lock nuts made from a special aluminum alloy
•Surface coating using Triple-C-Technology®for long-lasting corrosion resistance
•Round threads for easy adjustment
•Quality sport springs made from highly durable material
•Gas pressure technology
•BILSTEIN monotube technology, made in Germany
Photo:
Dernière modification par L'Frisé le jeu. juil. 06, 2017 11:54 am, modifié 4 fois.
L'Frisé
Re: FS: Bilstein B16 (PSS10) coilover STI 08-14, 1500$
ON drop ca a 1500$!!!
L'Frisé
Drop a 1300$
L'Frisé
Re: FS: Bilstein B16 (PSS10) coilover STI 08-14, 1300$
Je pourrais aussi echanger contre Mags BBS OEM 18'' avec pneus, ou turbo kit rotated ou autre.
L'Frisé
Pictures added
