À l'aide ---stud arriere sti 2016---svp
Alexjutras
Message par Alexjutras »
comment enlever les studs de roue arriere sur un sti 2016
Sti 2010 blanc perle (sold)
Sti 2016 bleu rally (on the road)
04_STi
Re: À l'aide ---stud arriere sti 2016---svp
Message par 04_STi »
im no expert, but i believe you need a special tool which will allow you to unthread them from the tire tread. after doing some reading, pliers can work too.
http://www.tirerack.com/winter/tech/tec ... techid=124" onclick="window.open(this.href);return false;
2004 JBP STi - Pearl I - RIP
GBH526
Message par GBH526 »
04_STi a écrit :im no expert, but i believe you need a special tool which will allow you to unthread them from the tire tread. after doing some reading, pliers can work too.
I think he means hub studs instead of tire studs. but i might be wrong..
Hey! Ho! Let's go!
WRX 2002 Track car still going !
TS 2002 drift car sold
Outback H6 2011 for sale
Crosstrek 2023 daily basic basic.... :facepalm:
yandpb
Message par yandpb »
Alexjutras a écrit :comment enlever les studs de roue arriere sur un sti 2016
peut tu prendre une photo et la montre son soi viser ou puncher
Wrx 2015
04_STi
you're very right. i never considered that. :oops:
wheel studs are press fitted. so you need to force them out. thread on a wheel nut and bang on the nut? use wd40 or liquid wrench.
https://www.youtube.com/watch?v=WnRGyj0hgXM" onclick="window.open(this.href);return false;
if you can remove the hub, im sure you could use a hydraulic press. maybe a bench vice?
Alexjutras
Problème résolu ,il faut enlever le galiper et après le hub après les stud peuvent s'enlever merci
