Tout d'un coup, le gear selector es tres "loose", es je ne peux pas engager , Reverse, Neutral, Drive, 3,2,1
Rien fonctionne, il me semble comme le char es tous le temps en neutre, car on l'a pousser sans meme avoir eu besoin de le metre en neutre.
Sur le dash, il es marquer comme s'il etait en 1ere vitesse.
Alors, quesque pourraient etre le probleme?
Le char es poigner dans un centre d'achat la
English
I am not sure what is going on with my mom's 2005 suabru impreza RS with AUTOMATIC transmission.
All of a sudden, the car won't start, and I can NOT change gear at all.
The gear selector is much looser than it was, and it goes very easily through all the gears, but does not engage any of them. Reverse, Neutral, Drive, 3,2,1...nothing works...
It seems as if the car is stuck in neutral, and the gear selector on the dash says I am in 1st gear, but clearly the car is in neutral as we pushed it without even having to put into neutral.
So what could be the problem?
The car is stuck in small shopping mall and need to get this figured out
