Different specs about the torqs and such.
Start by jacking up the car and setting up everything.
again, another 2 holes how-to :scurred:
A better picture of those 2 drain plugs.
I started by the trans plug. Take your torq bar with the 21MM socket and sqeeze it out. Watch out, lots of oil will be pouring down.
Take your 14MM and torq wrench, unbolt this plug out and let drain. At the point, you can remove the dipstick so it will be draining faster.
I let both of them drain for a good 10 min.
Since I was on jackstand only on the front, I jacked up the rear of the car and some more oil poured out, another maybe 2 min.
Remove the oil pan and replace the 2 plugs.
just a little view of those plugs.
Insert the funel in the trans fill hole and fill your trans with the new oil.
Check the level of your oil and you are done!
I'm sorry, I couldn't get a better picture of the dip stick.
