Je voulais les poser mais j'ai changer d'idées. L'alligneur a été capable d'alligner mon auto sans problèmes sur le camber à cause de ma nouvelle suspension. Neuf, jamais posés, in the box.
acheté 25$, à vendre 25$
EZ Cam(tm) XRs are designed for non-slotted struts. They allow both positive and negative camber changes up to approximately 1.75 degree (depending on vehicle) by replacing the upper O.E. strut/spindle bolt. This easy to use adjuster provides built-in adjustment over the life of a vehicle just by rotating the head of the bolt. Each kit contains two cam bolt assemblies, enough for both sides of the vehicle.
Part No. 81260 - Pair
For replacement of 14mm bolts
Front Adjustment range: Camber -1.75 degree to +1.75 degree
Installation time: .4 hr/side
Will work for both front and rear on Subaru WRX, STi (Front only for 2008+)
SOURCE: http://www.brz-parts.com/81260.html
